Shimano hydraulic hose codes- Mtbr.com
Results 1 to 5 of 5
    Reputation: spyghost's Avatar
    Oct 2012
    Reference is from this site: Brakes
    Deore, older, and non series
    SM-BH90-SS
    SLX
    SM-BH90-SB
    XT, XTR (M8k, M9k)
    SM-BH90-SBM
    Zee
    SM-BH90-SBS
    Saint
    SM-BH90-SBLS
    Look at the codes after the 2nd '-' ...
    Given the nature of the connections, I'd say that SS and SB stand for the connection to the brake lever and caliper respectively. I think, 'S' is 'straight,' and 'B' is 'Banjo.'
    Anyone knows what 'M,' 'S,' and 'LS' means?
    Why does SLX only have 'SB' in the end unlike XT, XTR, Zee and Saint.
    Oct 2012
    Well, found this site: 2015-2016 SHIMANO Product Information Web
    The difference between SB and SBM doesn't make sense though. The difference is in the length of the banjo fitting itself and the bolt that holds it.
    B A N N E D
    SS = Straight & Straight
    SB = Straight & Banjo
    SBM, the M means that the banjo & banjo bolt are compatible with the magnesium M987 & M9000 calipers.
    SBS, the S would be for standard banjo.
    SBLS, the L would be for long banjo, the last S is a mystery
    SM-BH90-SB = SLX 675, XT 785, XTR 985, XT 8000*
    SM-BH90-SBM = XTR 987, XTR 9000, XTR 9020**
    * Product info page lists the XT 8000 using the SM-BH90-SBM, a Shimano tech document lists the SM-BH90-SB
    ** The XTR 9020 is a aluminum caliper, you should be able to use the SM-BH90-SB with it.
    I've seen a few references for a SM-BH90-SLB hose for the Saint.
    Oct 2012
    Quote Originally Posted by cobba View Post
    "i think"
    SBS - <straight lever> <banjo caliper> <short bolt>
    SBLS - <straight lever> <banjo caliper> <long banjo> <short bolt>
    the japs should fix their naming, or it might be making sense from a jap perspective, but translating it to english directly creates a scratchead.
    Reputation: NazZaR's Avatar
    Jul 2013
    Thanks, guys. I've been scratching my head to understand what is the difference between SB and SBM, now it is all clear.
    XMCarbonSpeed CS-057 29er custom build
    https://www.strava.com/athletes/2293724
  1. Jagwire HyFlow Avid vs. Shimano Hydraulic Hose
    By agentorangemen in forum Brake Time
    Last Post: 02-27-2016, 05:45 PM
  2. Shimano Hydraulic Hose for Hope Brakes?
    By macming in forum Brake Time
    Last Post: 02-18-2015, 10:33 AM
  3. Replacing hose on Shimano hydraulic brakes?
    By allanmb in forum Brake Time
    Last Post: 11-04-2013, 02:19 PM
  4. Replies: 12
    Last Post: 12-15-2012, 06:41 AM
  5. Hydraulic hose is hose is hose?
    By PoorBehavior in forum Brake Time
    Last Post: 03-24-2011, 07:13 PM
Members who have read this thread: 15
