Saint Caliper Bleeder Screws Seeping Fluid- Mtbr.com
Results 1 to 5 of 5
    Reputation: Dawson308's Avatar
    I have had a set of 2010 Saint Brakes on my DH bike for 3 months now. My rear brake caliper started seeping fluid around the bleeder screw three weeks ago. I wiped it off and after every day of riding it would collect dust around the bleeder screw where mineral oil had slowly seeped out. It is not dripping or anything, it is a very light seep. I took the rear caliper bleeder screw out and carefully cleaned the bleeder screw and the bleeder screw hole. Next ride it still seeped. After a hard weekend of DH riding this weekend my front caliper started seeping the same way around the bleeder screw. Has anyone else had this issue and found a fix?
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    If your not experiencing braking problems like sponginess from sucking air dont worry.
    Formotion Products
    http://www.formot
    Meh.
    Reputation: XSL_WiLL's Avatar
    If there is an o-ring, check to make sure it is not twisted or torn.
    You can wrap a layer of teflon tape around the threads to prevent leakage.
    Jan 2005
    Sounds like seepage which is not uncommon with fluids.
    Formotion Products
    http://www.formot
    Thanks for the input everyone. The o-rings are in great condition. I am concerned the fluid might be seeping past the taper on the bottom of the screw and up the middle. I will try the teflon tape and see if that helps.
