    RockShox Tora 302 Solo - rotor size
    my front brake level broke when i crashed my bike so i am replacing the brakes. i was looking at this brake:
    http://www.pricepoint.com/detail/137...203mm-2007.htm
    apparently the fork will support a rotor up to 210 mm so i was thinking of getting 203mm. do i need any specific adapters for this particular fork to accomodate this type of a brake? still learning a bit. any help would be appreciated.
    Slick Rick
    Reputation: stefanb's Avatar
    Yes, you do need an adapter. Those might come with the 203's since the rotor does as well.
    Quote Originally Posted by stefanb
    it says it comes with the 51mm IS adapter and most forks work with it. so i assume that it will work. just not sure.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    Quote Originally Posted by Trix
    the Tora lowers use IS brake mounts, so it should work out fine...
