Rear J7not Working Properly- Mtbr.com
Results 1 to 3 of 3
    Reputation: jaco's Avatar
    New question here. Rear J7not Working Properly
    After a couple of rides the rear J7 I just bought has this tendency to make the wheel vibrtate in a strange way with this metallic sound to it, not a squeal though. Makes the bike feel weird but its hard to describe. Did I not break in the pads well enough? Might there be some premanent damage to the pads and/or rotors? Any ideas what might be wrong?
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Is it a stuttering feel with an agressive whirring sound associated with applying the brake? My rotors had very sharp edges which seemed to catch on the pads and make the brake feel choppy. I used a small diameter chain saw file to smooth the outer and inner edges of the wave shape on the rotor's brake track and this solved the problem. The edges I drew over in red, on the inside of the rotor (the side facing the spokes) are where I smoothed the edge slightly:
    <img border=3 src="https://gallery.consumerreview.com/webcrossing/images/rotorfile.jpg">
    If that does not help or you don't feel like messing with it, Avid will probably offer to send you new rotors like they did with me.
    tscheezy
    My video techniques can be found in this thread.
    Thanks for the detailed pic and suggestions. The brakes do feel choppy actually but theres no agressive whirr, only a nondescript metallic sound. I dont know Im even describing it properly. In any case, I will try smoothing the edges see if this helps.
  1. Your experience with SID rear shocks?
    By dgangi in forum Shocks and Suspension
    Last Post: 02-07-2004, 12:15 PM
  2. Theoretical question for suspension geeks
    By Steve from JH in forum Bike and Frame discussion
    Last Post: 01-17-2004, 01:33 PM
  3. Loco rear shock choices
    By LocoToo in forum Titus
    Last Post: 01-15-2004, 11:14 AM
  4. Rear Wheel Removal
    By wilsonblur in forum Santa Cruz
    Last Post: 01-12-2004, 04:27 PM
