Rear hub / Disc brake question- Mtbr.com
Results 1 to 2 of 2
    MountainMafia "Boss"
    Reputation: MountainMafia's Avatar
    I'm converting over to amech. disc brake from a V-brake in the rear. The question is, are all hubs Disc brake cpmpatible? I have nothing to bolt the rotor to, so is there an adapter that I can get from my LBS?
    Any info would be appreciated.
    Thanks.
    "Live to ride... FREERIDE to live!!!!!!"
    Meh.
    Reputation: XSL_WiLL's Avatar
    If you've got nothing to bolt the rotors to, your hub is not disc compatible (unless it's a Shimano Centerlock).
