Re-use Guide T brake hose with rear disc brake upgrade?- Mtbr.com
Results 1 to 3 of 3
    Nov 2018
    I recently purchased Guide G2 rsc brakes to upgrade my Guide T brakes that came stock on my bike. Iíve replaced, shorted the cable and bled the front brake fine, but Iím wondering about just using the same hose for the rear brake to avoid having to swap internally routed hoses. Does the Guide T brake use the same Stealthamajig adapter, or should I use the new hose? Any tips for swapping the internally routed hoses out?
    Dec 2008
    Fine to re-use hose just pop a new red thing a ma jig on
    Reputation: Lone Rager's Avatar
    Dec 2013
    Does the old hose have the correct fitting at the caliper end?
    It's easy to run a new hose too. Use a little red SRAM coupler to connect the two hoses and use the old hose to guide the new hose as you push it through. (don't try to pull it through with the old hose). If you don't have a coupler, you can use a ~2' length of brake cable stuck equally into the old and new hose to guide it.
    What, me worry?
  1. Upgrade from Guide RSC to Code RSC - use same hose?
    By lardo5150 in forum Brake Time
    Last Post: 05-22-2019, 08:47 AM
  2. Sram brake hose used as reverb hose.
    By Trailmonkee in forum Bike and Frame discussion
    Last Post: 09-18-2017, 06:38 AM
  3. 2012 xtr brake hose same as avid xx hose?
    By mtbpri in forum Shimano
    Last Post: 02-22-2012, 09:03 PM
  4. Hydraulic hose is hose is hose?
    By PoorBehavior in forum Brake Time
    Last Post: 03-24-2011, 07:13 PM
  5. Avid Mech Pad Squeal Re- Re- Re-visited
    By qcanoe in forum Brake Time
    Last Post: 05-19-2005, 10:06 PM
Members who have read this thread: 23
