quick Shimano banjo bolt question- Mtbr.com
Results 1 to 1 of 1
    Uncle
    Reputation: Entrenador's Avatar
    I'm changing a brake line on a set of the m555 at the moment. It came with new orings to go either between a) the banjo and the caliper, b) the banjo and the bolt, or c) one on each side (though there was only one when I dissembled it.) It came apart too quickly for me to see where exactly the oring was. Anyone here know which side the of the banjo fitting the oring should go?
    It's apart in my living room, so quick & accurate responses are VERY appreciated
    Nevermind... Just had to poke around the Shimano site a bit further. For what it's worth, the document is there, it's just not located in the most ideal spot.
    Happy New Year
    Last edited by Entrenador; 12-29-2006 at 07:50 PM. Reason: needed better explanation
