Question about 2008 BB7's on PricePoint- Mtbr.com
Results 1 to 2 of 2
    http://www.pricepoint.com/detail/150...203mm-2008.htm
    The listing shows these 2008 model are available for the rear only. Is that correct? No front spacers included? I want to run 185F/160R. The 2009 BB7 are listed as working on front or rear with both spacers included. Are the 2008's different from the 2009's? The 2009 185mm BB7 is $51.98 vs. the 2008 185mm BB7 at $39.98. Just trying to save a couple bucks if they're the same.
    I'm 6'2' and 200 lbs. Should I be going 203F/185R instead? I live in the midwest (Michigan) and ride general XC-type trails. I'm assuming I would only need that large of rotors for serious DH use.
    2010 RockHopper Comp Disc
    They just come with different mounting brackets. The 2008 only comes with the rear and the 2009 comes with both the front and rear.
    Tip use jensons pricematch
