    Pressure on brake lines when hanging bike
    I recently bought my first bake with hydraulic brakes. Normally I store my bike by hanging the top tube on hooks.
    My new bike has all of the cable routing on the bottom side of the top tube. Is there any risk to hanging the bike this way, since the brake lines will have pressure out on them?
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    can you adjust the hooks? maybe try stem/saddle as hooking points?
    I don't think the hanging will be a serious issue... but could cause some cable rub, etc. if you are not careful getting the bike on/off the hooks...
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Or maybe setting the hooks so they are at the end of the top tube where the cables usually get further from the frame? I would prefer not to have the bike's whole weight resting on the cables and hoses...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    STINKY TOFU
    Reputation: dragonhead08's Avatar
    I just replaced my old hydros and had the same problem. As I was removing the line and I saw where the hook was sitting and it did put a crimp into the hose. I dont know what effect it had on the performance as I was swapppin em out for some new formulas.
    "I'd pee on that"
    -R. Kelly-
