post mount fork to IS caliper adapter sources?- Mtbr.com
Results 1 to 5 of 5
    i know they make these and jenson has a shimano one for 22 but that is expensive. anyone know where to get one cheaper?? somthing like this 180 or 200mm is fine http://www.pricepoint.com/detail/182...ke-Adapter.htm
    RIP Friendgirl
    Reputation: Bordershy's Avatar
    I just installed an IS "short arm" caliper to a PM fork with that pricepoint alligator adapter & it works with a 180mm rotor.
    Not sure how they expect a 203mm rotor to fit unless you use a long arm (rear) caliper.
    Update: With a short arm IS it fits a 190mm rotor. Go figure.
    I think the one you want is this one from PricePoint;
    http://www.pricepoint.com/detail/112...ke-Adapter.htm
    A friend has used one already and it works fine. It is steel so its heavy but other than that it is fine. Magura makes them it is a #3 but also expensive. You have to contact them to see what it is retail.
    Magura adaptor is steel and heavy.
    Turns out I just got the a Magura #3 adaptor and is it steel and heavy. Since the one from PricePoint is also steel and cheaper I would just get that one. Just an update.
    Reputation: vk45de's Avatar
    Quote Originally Posted by Bordershy
    Going is smaller is hard, going bigger is easy. Here: also at pricepoint
