Results 1 to 6 of 6
    Post to IS adapter 160mm rear....does it exist?
    New bike has160mm rotor and 74mm post mounts. I have a set og xtr 975 IS mount brakes that I'd like to move to the new bike. I have the correct front adapter but can't find a specific mount for the rear. Can anyone point me in the right direction?
    T.W.O.
    Reputation: mimi1885's Avatar
    I did it once on IS marta sl. I don't know which adapter I used, I just pick it from my assorted adapters. In general you just need to up a rotor size.
    Singletrack Addict!!!
    Reputation: Relayden's Avatar
    Jun 2005
    You need to go either shimano 170mm(shimano only adapter) or any other 180mm rotor.
    The world needs a huge socio-economic change...be it. We all need to ride more....
    Quote Originally Posted by Relayden View Post
    So are saying use a fr ont 160mm post to is adaptor with a180mm rotor? I'm not seeing anything in regards to a 170mm. Any chance you can give me a link to what youare referring to or a product number?
    Maybe he meant 180 but here is the tech doc on it with the adapters and shimano part numbers
    http://techdocs.shimano.com/media/te...9830609100.pdf
    B A N N E D
    IS brake to PM fork adapters.
    160mm: http://cgi.ebay.co.uk/KCNC-Disc-Brake-Adapter-POST-Anodised-RED-160mm-/280671676319
    * This adapter doesn't work with all IS brakes but I've read that people have used it with XTR models on forks.
    170mm: http://www.chainreactioncycles.com/Models.aspx?ModelID=13744
    *170mm rotors are harder to find then the standard sized rotors.
    180mm: http://www.actionsports.de/gb/Components/Brakes/Disc-Brake-Accessoires/Shimano-Mountadapter-SM-MA-F180S-P-PM-to-IS-180-Front::26473.html
    I don't know if these adapters would work on the rear.
    As far as I know there is no rear specific version for this type of adapter.
  1. Replies: 0
    Last Post: 06-27-2011, 01:27 PM
  2. rear post to post 140-160mm adapter?
    By Steveorocks in forum Brake Time
    Last Post: 06-18-2011, 11:42 AM
  3. Post mount adapter? 160mm to 180mm
    By pocketdrummer in forum Beginner's Corner
    Last Post: 07-21-2009, 08:50 AM
  4. 185mm FR adapter = 160mm rear?
    By Kyle2834 in forum Brake Time
    Last Post: 10-23-2007, 02:53 PM
  5. Replies: 5
    Last Post: 06-08-2007, 06:28 PM
