Plastic Wedge- Mtbr.com
Results 1 to 17 of 17
Thread: Plastic Wedge
    Plastic Wedge
    hey guys, what is that plastic wedge thing called that keeps the pads from closing when you have the wheels off and somebody squeezes the brake lever? and is that thing sold anywhere? would like to have one around when i'm on the trail just incase so i don't have to pry the pads if i accidentally grab the brakes when the wheel is off
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Get it @ your LBS .
    Aug 2010
    I call it "that plastic wedge thing" and +1 on getting it from your LBS. Mine came from the good ol' junk bucket there.
    Reputation: dietz31684's Avatar
    avid calls em bleed blocks...but im pretty sure plastic wedge gets the point across.
    yeah. just got to make time to go out to the LBS. finding out the name is what's really killing me. the plastic brake thingy. lol
    thanks dietz. looked up bleed block and on the picture is says pad spacer.
    AZ
    AZ is offline
    Quote Originally Posted by blindman22
    pad spacer.
    This , sorry I did not include that in my post .
    no worries AZ.MTNS. you always come thru with solid info on my posts.
    Aug 2010
    Ok, now that we've solved that, let's move on to what those plastic things around the ends of shoe laces that keeps them from unraveling are called . . .
    Quote Originally Posted by roxnroots
    aglet i believe. they did an episode of phineas and ferb on it (i have kids)
    Aug 2010
    Well, that was easy. on that bit of trivial pursuit.
    lol. who knew cartoons were so informative.
    in a pinch, use a couple of quarters
    We Ride In God's Country!
    Reputation: chuggboy's Avatar
    Jan 2005
    Can't see how a few coins will stop my shoelaces fraying!
    C
    Quote Originally Posted by chuggboy
    C
    in a pinch. chewing gum will work.
    Tool
    Reputation: Pedalphile's Avatar
    One thing to realize is that you'll likely have to pry the pads apart to get the bleed block in. The bleed block is designed to push the pistons all the way in so that you don't put too much fluid in the system while bleeding.
    -Pete
    I can barely get my mouth around it.
    Reputation: MudInMyEars's Avatar
    Apr 2005
    What do they call those rubber things used for birth control?
    Oh yeah, rubber bands.
    _____________________________________________
    Fat, drunk and stupid is no way to go through life, son.
