The perfect caliper brake shim- Mtbr.com
Results 1 to 5 of 5
    Reputation: CactusJackSlade's Avatar
    The other night, it happened to be late and a saturday so no chance of getting to my local LBS with a ride going with the buds Sunday AM...
    I had a rubbing rear XTR brake... and with this style you have to use shims to center them. I looked around for small washers, shim material anything, but nothing about my garage fit the bill.
    I though, well, I might as well measure the thickness and see what I needed, so I did using a feeler guage, then I started thinking... hummmmm
    Well I ended up drilling a hole in the feeler guage of the perfect thickness, then cutting it off with my dremel tool , rounding the edges and voila! Perfect shim
    I actually like this better than multiple shims, only one to deal with and it's semi-captive on the bolt...
    Largest NorCal XC Race Series
    http://www.bicyclingevents.com
    http://www.UavTechReview.com
    Best in the West!
    Jul 2003
    Not bad in a pinch....
    but you just ruined a perfectly good feeler gauge! A good "desperation fix" though.
    Good Dirt
    Expensive shim!?!
    Jan 2009
    lol been there done that on my motorcycle caliper...... had to use thin washers on my 755 shimano rear caliper to center it on the disc on the yeti......
    Quote Originally Posted by Squash
    Good Dirt
    Naw... I just cut a half inch or so off the end, still good, I promise!... unless my front needs the same size too
    Best in the West!
