Is it normal for...- Mtbr.com
Results 1 to 14 of 14
    pain Only Hurts for a min
    Feb 2010
    Is it normal for...
    So I have never had any noises coming from my brakes (except minor squeaks while it is raining) until recently. How that is it getting colder out I have noticed a increase in the squeaks and howling while braking.
    Is it normal for disc brakes to make loud, howling like noises when wet and/or cold?
    Just a Kid chasing his Dreams
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Quote Originally Posted by moutainkiller
    Yes, it's normal, more for some brake brands, rotors and pad compounds than others. The colder weather means the pad compound hardens just a little resulting in more noise until they have warmed a little from use. They also should work a little more effectively as they warm but not overheat. Avids tend to be fairly noisy until dry and warm ime.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Feb 2010
    Is anyway to limit the noise, other than buying new brakes?
    Never trust a fart
    Reputation: frdfandc's Avatar
    New brakes could do the same thing. I'd try a set of organic brake pads first, with a quick scuff of the rotor with some sandpaper.
    Feb 2010
    Quote Originally Posted by frdfandc
    Why do this? To smooth it out so that it can start fresh with the new brakes?
    On wuss patrol
    Yes. Couple things to keep in mind: organic pads are a little quieter but they do wear a little faster than metallic sintered pads and they fade a little faster under heavy braking.
    Brake noise is a part of riding so it's necessary to learn to live with some.
    Do a forum search in Brake Time with any questions or topics you are interested in and you'll learn lots.
    BMW 2002, Dodge A100, etc
    Reputation: Pimpride's Avatar
    Double check to make sure everything is tight. A loose disk, or caliper will increase noise/vibration..... New pads help too if they've been used/abused.
    Reputation: gticlay's Avatar
    My brakes aren't loud in the summer, but are more quiet in the winter with all the water and mud on them.
    "It looks flexy"
    Reputation: superjesus's Avatar
    Quote Originally Posted by Malibu412
    I disagree with this. IME, my v-brakes have been dead quiet all season, even on stock pads. The only time I've had even minimal noise is when my rims get dirty. YMMV.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    ^^^ how's the DH goin for ya?
    ANYWAYS, you can try adding some graphite (I've been flamed for this before) to smooth out the resonance....honking esp.
    I personally have not done it on Organic pads - So if you have them, start off careful.
    On metallics it works great - the first few stops are going to be needed to be 'bedded-in' but after that, it should quiet a bunch (provided you have good caliper alignment etc)
    OH! if you know graphite, a little goes a looooong way
    Honestly... ahh I give up
    Reputation: shiggy's Avatar
    Dec 1998
    I find organic pads to be total c**p and howl in wet conditions.
    mtbtires.com
    Dec 1998
    Fairly normal for disc brakes to make noise any time the conditions change. I have had dusty summer rides where the brakes started howling after a stream crossing and continued to until after the second creek a mile away.
    mtbtires.com
    On wuss patrol
    Quote Originally Posted by superjesus
    Now we weren't talking about lame a$$, outmoded, last century technology rim brakes were we?? Besides, you just proved my point with your admission of noise with dirty rims. As I said, learning to live with some noise is part of riding.
    Feb 2010
    haha Play nice children!
    Thanks for advice everyone...I'll let ya know how it turns out.
