need to shorten my hydro lines, best cut?- Mtbr.com
Results 1 to 7 of 7
    so, need to shorten a hydro line for the first time. searched on this but didn't come up with much.
    I've never cut them before. not having the $xxx hydro line cutter, what is my next best option? Dremel? Razor blade?
    Jagwire space age tool. It's not very expensive.
    Otherwise I would recommend some sort of saw, perhaps some electrical tape around it. You'll still get some frayed edges that you'll have to hit with a lighter. The Jagwire tool is fast and clean.
    cool. thanks schmucker.
    Rabid Lana Fan
    I always use a razor blade.
    Just make sure to use a brand new one....it gives a nice clean cut.
    And make sure you cut it square.
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
    Meh.
    Reputation: XSL_WiLL's Avatar
    I use a fresh razor blade as well. It works just fine.
    Saw won't work very well unless it has very fine teeth.
    Oaktown Honkey on Strava
    Brand spankin' new razor
    The thicker, made in U.S.A., heavy duty guage steel. Not cheapo. Glasses and Gloves ( seems overkill but I am a tradesman that knows many mangled guys )
    Reputation: mitzikatzi's Avatar
    Something like this
    here
    I don't like just using blades to cut. I only have 8 fingers and two thumbs.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
