My front break is making a loud squeeking sound ,- Mtbr.com
    Apr 2014
    I ride a 2013 trek remedy 9.8 , I take the front wheel off everyonce in a while to transport it. I took my front wheel off, and put it back on my front fork, and now it is making and super loud squeaking noise. Is this bad? what do I do to fix/solve the problem
    Thank you,
    Jesse
    Barrett
    WillWorkForTrail
    Jun 2012
    Check the pad/rotor alignment. Is it dragging? Or is this happening when you apply the brakes? Do the brakes feel weaker than they did before they started making noise? If the pads are dragging, you'll have to spread them apart. They likely started because you pulled the brake lever while the wheel was off. If it's just making noise when you apply the brake and doesn't have the power it did before, you've contaminated the pads with something, either that got directly on them, or that got on the rotor, then the pads. This could really be as simple has you having touched the rotor, especially if you were sweaty at the time.
    Apr 2014
    yeah i think its just the rotors are rubbing ? like if i do a wheelie the front wheel will spin then lock up? so should i get like a butter knife slip it in ther spread it then put my wheel on ?
    WillWorkForTrail
    Jun 2012
    I wouldn't use a butter knife. Take the pads out and push the pistons back in with a large screw driver or something. It will require a bit of force, but apply that force gently. Remember, these are relatively precision bits of equipment.
  1. Help, Disc Break making a weird noise
    By JuanMolina in forum 29er Components
    Last Post: 02-04-2014, 10:57 PM
  2. Replies: 2
    Last Post: 06-13-2013, 06:19 AM
  3. My Bike is Making a Sound
    By mtbxplorer in forum Commuting
    Last Post: 07-28-2012, 09:32 AM
  4. RP2 DRCV making creaking sound
    By jrk07 in forum Shocks and Suspension
    Last Post: 11-21-2011, 02:04 PM
