mix n match shimano LX ST-M585 with XT caliper (M765) OK?- Mtbr.com
Results 1 to 22 of 22
    I have been given LX dual control levers(ST-M585) without calipers. I saw a special on XT calipers (M765), so I am wondering if I can use them. I know you aren't meant to mix n match different levers and calipers, but the LX and XT combination looks like it will work ok.
    Help!!
    Is Muddy
    Reputation: Intense5point5's Avatar
    The Shimano Hydraulic systems are all compatible with each other. All you need to do is change the fittings and essentially make an LX end and an XT end for your hose. I've seen Deore/Saint LX/XT Deore/XTR, etc... I personally run XT/XT but thats just because they were available locally.
    2007 Waltworks 29er,
    2007 Intense 5.5 EVP,
    2006 Specialized Langster,
    2002 Giant DH Comp,
    1993 KHS Montana Comp SS.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    yep.. no problem... I run exactly that setup on my SS, as Intense5point5 said, you just need the right hoses/fittings
    you need a 0 degree fitting at the lever and a 90 degree fitting at the 760 caliper, or just get the SM-BH63 hoses, that come with those fittings
    JensonUSA has the LX calipers for $25 apiece...just sayin'
    Quote Originally Posted by theRuss
    those need a different hose than the XT (just in case )
    Is Muddy
    You can pair anything with anything. Whether it works or not is another problem...
    2002 Giant DH Comp,
    Reputation: brewdog's Avatar
    saw posted in another thread via "search" that "it's all the same at the caliper end".
    Will the BH63 work on LX calipers?
    Quote Originally Posted by brewdog
    no... the BH63 has a 90 degree connector at the caliper end, and the 580 LX use a 0 degree connection at the caliper, and the 760 XT use a 90 degree one (the new 08 770 XTs and 970 XTR use a 0 degree connector)
    here you can see the 760 XT caliper and BH63 hose
    <a href="https://www.flickr.com/photos/cmadrigal/314120733/" title="Photo Sharing"><img src="https://farm1.static.flickr.com/103/314120733_6189fc59f9_o.jpg" width="800" height="600" alt="180mm rear disc brake" /></a>
    here's the 08 XT, the 580 LX use the same hose/connection
    <a href="https://www.flickr.com/photos/cmadrigal/1347954750/" title="Photo Sharing"><img src="https://farm2.static.flickr.com/1107/1347954750_e6e5ae5ec9_b.jpg" width="768" height="1024" alt="2008 Shimano Deore XT brakes" /></a>
    Reputation: dnlwthrn's Avatar
    Since the OP has the LX levers already, wouldn't he be better off with the LX calipers? Of course, I have no idea if said levers came with hoses or not. If not, then its all up to what he wants to spend. Personally, I've played with the DC levers and prefer my switchgear separated from my brake levers. I got the M585 calipers and levers from Jenson a couple weeks ago. Now I just need to get wheels with disc hubs!
    Crisillo - Thanks for the info.
    So from what I gather via the Shimano compatabilty chart and your post, I need SM-BH59 for the LX 585 calipers from Jensen.
    Any chance you know what fitting kit I need to set up the BH59 hoses to 96X shifters?
    Quote Originally Posted by dnlwthrn
    ...I got the M585 calipers and levers from Jenson a couple weeks ago...
    did the levers/calipers come with the hose?
    Is Muddy
    Crisillo - If that is a recent photo, fix your gad dang rear QR.
    On another subject, for the thread starter, we won't go about and look for these things for you. (AKA Part numbers, prices, etc..) but If you find what you THINK you need, I'm sure one of the nice people on these forums would proof it for you before the purchase order.
    2002 Giant DH Comp,
    Quote Originally Posted by Intense5point5
    no worries..that is an old pic...this my current setup
    <a href="https://www.flickr.com/photos/cmadrigal/1347062897/" title="Photo Sharing"><img src="https://farm2.static.flickr.com/1347/1347062897_148e48bdb7.jpg" width="375" height="500" alt="2008 Shimano Deore XT brakes" /></a>
    no prob... yeah... if you go with the LX calipers the BH59 will be fine
    for the 965 shifters (older XTR), you need a 90 deg. ftting at both ends (so you can only use 760 or 960 calipers with it, the hose is SM-BH96), see here http://www.paul-lange.de/produkte/sh...-R_ST-M965.pdf
    Cool, thanks for all the info.
    Levers were $59.99 with hoses, calipers/rotors were $25 and $21.50. These are 160mm centerlock rotors, btw. I also got some other stuff at the same time, so shipping was more. I think for just the brakes it came out to around $112-115 shipped.
    Meh.
    Reputation: XSL_WiLL's Avatar
    If anybody wants some new LX DC levers, I've got a set that I'll let go for dirt cheap (without hoses).
    So it turns out the guy has 965 DC's and possibly 585's on the way(not sure if he's ordered them). That won't work with any of the hoses, will it?
    Is Muddy
    brewdog - thats what we've been explaining. If you have both a lever and caliper with different fittings, no problem. If no fittings are available for a specific type of hose, thats the problem. If the hose diameter is universal and the fittings are for different size/ type hoses, then your basically screwed unless you own a machine shop or know how to jerry-rig a working fitting assembly.
    As for absolute universal compatibility, the only lever/ caliper combo that may have compatibility issues with interchange are the Grimeca/Shimano XT BR-M755 4-Piston calipers. These were not produced by Shimano but rather, purchased in bulk from Grimeca and modified for use with mineral oil. I haven't had a chance to test this myself, but I believe that the BR-M755 System is on a different branch of the Shimano family tree.
    (BR-M755's are awesome BTW.)
    Edit: Now that I think about it, just ONE hose won't work. You need extra fittings, or the other hose with the fittings in order to have a compatible lever/caliper set.
    2002 Giant DH Comp,
    Thx for the heads up - got a set. They a come rotors and adaptors - which is great value.
    Meh.
    XT m755 4pot calipers worked just fine with XT, Deore, and LX levers. I've set them up as such. And all the fittings I needed were in the Shimano Small Parts Kit.
    Is Muddy
    Cool, I just wasn't sure.
    2002 Giant DH Comp,
