Results 1 to 5 of 5
    Relentless forward motion
    Reputation: strat819's Avatar
    Marta Mag SL plus Alligator Wind Cutters
    TIA
    Anyone out there run Alligator wind cutters with Magura Marta SLs?
    Any compatibility issues? If not, how was/is the performance?
    Reputation: mtbnozpikr's Avatar
    I can't comment on the Alligators from personal experience (I've heard they aren't too good) but I ran the Ashima Airotors once upon a time on mine. They are extremely light, inexpensive, compatible, and have plenty of power. If you haven't bought rotors yet, I would suggest either the Airotors or Storm SL's. I currently have the Storm SL's and like them too.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
    I have this setup, well older marta sl's, works fine for typical XC......only problem is really steep or long downhill sections...you'll get some fading......they get so hot you get burning smell, cooked rotors and pads.......so you're rotors will get discolored and pads will get glazed and require a sanding...
    dirtbag
    Reputation: ranier's Avatar
    Sep 2003
    Storm SL rotors with Marta SLs rock. nuff said
    Amolan
    Lucky Flyer
    Reputation: aaronutah2's Avatar
    alligator iwave and marta sl. no problem.
  1. Replies: 86
    Last Post: 06-22-2010, 07:42 AM
  2. 140mm Alligator Wind Cutter Rotor in US
    By mtnfiend in forum Weight Weenies
    Last Post: 10-31-2009, 08:59 AM
  3. 140mm Alligator Wind Cutter Rotor in US
    Last Post: 10-29-2009, 04:19 PM
  4. Where to buy Wind-Cutters
    By Lelandjt in forum Weight Weenies
    Last Post: 07-25-2009, 11:09 AM
  5. Alligator Wind-Cutter Rotors...
    By PimpinD in forum Bike and Frame discussion
    Last Post: 03-04-2009, 10:22 PM
