Maguras from 26" to 29" bike- Mtbr.com
Results 1 to 2 of 2
    I have a set of 2009 Magura Marta SLs that I want to transfer from my 26" bike to my new 29". The lines are perfect length for the 26, so I assume I am going to need new brake lines.
    What is involved and what can I expect to spend assuming that I have a shop do it for me.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Why don't you check to see if the lines are long enough?
    Otherwise you will need new lines and fittings. The lines will need to be cut to length, fittings installed, install the hose, bleed the brakes.
    As for price... why don't you call a shop and ask?
