Lubed piston, rebuilt caliper, piston still sticky, now what?- Mtbr.com
Results 1 to 6 of 6
    Jan 2005
    So I've rebuilt the front Juicy 7 on my bike and lubed and re-lubed the sticky piston, but it still won't actuate like the opposing one leading to lots of rotor drag. For a long time I thought there was something wrong with my fork dropouts because the rotor wouldn't stay centered until I discovered one piston protruding more than the other. Any suggestions? Should I send it back to Avid for them to take a look? It's damn frustrating.
    Thanks for any help!
    -jon
    Feeding your addiction
    Reputation: Ventanarama's Avatar
    Dec 2001
    Quote Originally Posted by jlang002
    -jon
    I'd recommend getting the caliper rebuild kit and replacing the pistons.
    Larry
    Mountain High Cyclery
    larry@mtnhighcyclery.com
    "It is inhumane, in my opinion, to force people who have a genuine medical need for coffee to wait in line behind people who apparently view it as some kind of recreational activity". - Dave Barry
    ...idios...
    Reputation: SteveUK's Avatar
    A piston seal will go long before a piston. The seals are responsible for the return of the piston, so when one fails you end up with a piston that won't retract. Unless there's obvious damage to the piston, replacing the seal should be enough to fix your problem.
    Diogenes
    Jan 2005
    Quote Originally Posted by SteveUK
    I don't think it's a retraction issue. The one piston won't actuate unless I hold the other one in its bore. I was wondering why I had to keep moving my caliper away from my wheel to keep it centered. Probably still a seal issue, but might as well replace the pistons since they come with the kit. If this doesn't solve it I give up on the Juicys...I've had so many issues with these things. Great deals on K24s out there!
    -jon
    MTBiker
    As long as they both move it should be okay if you can just get it centered. On my brakes, one of the pistons moves slower so I just offset the caliper and it works now
    Jan 2005
    Quote Originally Posted by kuksul08
    The one piston really doesn't move at all leading to pretty significant rotor drag. I have to keep moving the caliper out and away from the wheel before every ride. I'll be picking up a rebuild kit on Sunday and seeing if I can get the thing working. If not, I'm springing for Formula.
    -jon
