I hate Post Mount System!- Mtbr.com
Results 1 to 25 of 25
    Daniel the Dog
    I have a Fox F29 with that stupid post mount system. I hooked my post mount Hayes up to that fork and the rotors is too far to the inside and is rubbing. I can push the rotor anymore to the outside to get the rotor centered. Dang, Fox, I want internation standard. I probably will have to get a rotor shim to fix it. Sheesh!
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    You can say that again!!
    Formotion Products
    http://www.formot
    its not the post mount thats the problem, as Manitou and Rockshox manage to do it perfectly without that problem.....the only issues I ever hear with the rotor hitting the fork mounts (which is what I'm assuming the problem is) is on Fox.
    Old man on a bike
    I was saying how much they sucked just recently, after stripping a thread Fortunately a helicoil came to the rescue. Can't strip the IS mount and like the shim capabilities, too. Had hoped they'd die off with manipoo.
    suum quique
    Funny actually, its the shims that turn me off IS......diff strokes for diff folks eh??
    Live 2 Ride
    Reputation: Kona0197's Avatar
    I'm happy my fork uses the IS mount.
    My Bike: '18 Giant Talon 3 29er
    My Blog: http://http://kona0197.wordpress.com/
    ...idios...
    Reputation: SteveUK's Avatar
    Quote Originally Posted by Bikinfoolferlife
    It's as easy or easier to helicoil a PM than it is to repair a stripped IS caliper. That said, threading a PM or a caliper is not the fault of the component; is it.
    Diogenes
    Post mounts need longer caliper mounting bolts a lot of the time. If you use the stock length bolt its far more likely to tear out those fragile magnesium threads or tear off the caliper if it takes a hit. More threads engaging is a good thing here. I have seen a F29 with avid elixers where the bolts only went in about 1/8th of an inch and of course were torn out when the caliper took a hit on a roof rack with no wheel in there. Didn't even need a helicoil to fix it, the longest possible bolt did the trick.
    I also like IS because of the cheaper more available facing tools which are so very necessary for non avid brakes. A faced IS tab is tough to beat for precision.
    err, 27.5+
    Reputation: AL29er's Avatar
    This post needs MOAR SHIMZ
    Blame the stupid tight tolerances driven by weight weenies who can't handle the extra 20g of metal to give the brake calipers a broader adjustment range.
    Quote Originally Posted by saturnine
    that's the stupidest idea this side of pinkbike.
    Jan 2005
    Post mounts rule!!!
    Formotion Products
    http://www.formot
    Peace & Love
    Reputation: FoShizzle's Avatar
    seriously? post mount rules...get some non retarded brakes maybe.
    i am sure that post mount also hates you jaybo
    Daniel the Dog
    Oh, Mr. Fo
    Quote Originally Posted by FoShizzle
    I bet you have never screwed a bolt into a post mount have you? Come on, you can tell us.
    Peace & Love
    Quote Originally Posted by Jaybo
    what does that have to do with it? and no, i have not
    Old man on a bike
    Quote Originally Posted by SteveUK
    Don't have an IS caliper, but indeed that would be a bigger pain...while I'm talented enough to screw up the post mount threads, I have a bunch of IS to PM adapters, none of which I've managed to fock up I still would prefer the additional shim capabilities of the IS mount, though. Probably just have to get used to it, as it looks like the tide is going the PM way...
    suum quique
    Reputation: vk45de's Avatar
    We are here talking about how we like screwing an IS over a PM, so if you haven't screwed either, then your opinion sucks.
    POG
    POG is offline
    Pudgy Old Guy
    I've used both and much prefer post mount.
    Reputation: Henchman's Avatar
    Jaybo: You sure your hub is correctly centered with it's axel?
    Feb 2007
    I've got both on my bike, I think a well shimmed IS mount is great. a post mount is easier to adjust, both are fine.
    San Miguel Beer Drinker
    i like post mounts better but i wish that manufacturers use other materials like steel for the threads. i've stripped the thread on my marz already.
    post mount is crap.adjustability is worse,you make little error with threads and your fork or even worse,your frame is worthless.and industry wants exactly that !! usefulness in weight loss is laughable.
    need more bikes...
    Jan 2005
    Quote Originally Posted by enio
    You need to use a LBS.
    Formotion Products
    http://www.formot
    ...idios...
    That's like saying that any threaded component is a liability and a ploy by the "industry" to make you buy more stuff. What a load of nonsense. Just don't make mistakes. If you're incapable of fastening bolts, take your bike to shop.
    Diogenes
    Reputation: eyescream's Avatar
    YOu should probably just ask to get removed from the site, that will fix it
    I hate PMS, usually ends with a lot less screwing than you guys are talking about.
    Reputation: slowrider's Avatar
    I prefer post mount!
    In fact I've never had issues with post mount. Yesterday however I mounted my IS Hopes to my IS fox Talas and with no shims the caliper is too far in. I had these mounted without issue earlier in the year, but after a breif stint on my 1fg they are somehow not working with the old fork.
    I've been considering facing the IS tabs but the fork worked fine with the post mount Juicy ultimates I just sent back to Avid for Warranty work.
