I hate Post Mount System!- Mtbr.com
Results 1 to 11 of 11
    Daniel the Dog
    I have a Fox F29 with that stupid post mount system. I hooked my post mount Hayes up to that fork and the rotors is too far to the inside and is rubbing. I can push the rotor to rotor anymore to the outside to get the rotor centered. Dang, Fox, I want internation standard. I probably will have to get a rotor shim to fix it. Sheesh!
    Reputation: Hardtails Are Better's Avatar
    May 2005
    So you'd rather have to shim the caliper to align things than shimming the rotor? Seems like six of one, half a dozen of another to me.
    Jan 2009
    New question here.
    Quote Originally Posted by Hardtails Are Better
    thats what im thinking....small washer under each disc bolt and done deal... unless its a 1/4" off....
    Live 2 Ride
    Reputation: Kona0197's Avatar
    It's easier to shim an IS mount. Two bolts to shim instead of six.
    My Bike: '18 Giant Talon 3 29er
    My Blog: http://http://kona0197.wordpress.com/
    Reputation: slowrider's Avatar
    Never had an issue with post mounts before myself, set the caliper on the posts without any effect from the brake line, squeeze the lever, thighten the bolts, ride. Shims suck; try filing the caliper holes.
    ...idios...
    Reputation: SteveUK's Avatar
    Quote Originally Posted by Kona0197
    Not at all. There's only one (proper) shim needed to shim a rotor, not six.
    Diogenes
    No Clue Crew
    Apr 2005
    Despite all the reasoned arguments, I, too, prefer IS mount to post.
    switchback sculptor
    Reputation: erosive's Avatar
    Syntace's shims are a better option for fine tuning. .2mm vs the hope's 1-2mm.
    http://www.universalcycles.com/shopp...s.php?id=11646
    I'm gonna have to kill ya
    Reputation: roybatty666's Avatar
    be a man and file out the slots on your caliper (I had to to fit 2 piece hope rotors)
    Post mounts are fine, I have yet to work out why so many people moan about them (despite the weekly threads about them )
    Daniel the Dog
    Laugh
    Quote Originally Posted by roybatty666
    Yes, filing is always a sign of a great system
    Live 2 Ride
    Quote Originally Posted by SteveUK
    You still have to remove and install six bolts instead of two.
