Hydro brakes overheating?- Mtbr.com
Results 1 to 2 of 2
    Reputation: Casual Observer's Avatar
    Just replaced my Avids with Formula RXs about two months ago. Had a hell of a time trying to get the pads centered since this is no pad adjustment. As far as I can tell, visually the rotor appears centered. However, without fail, about 30 or so mins into the ride, I get the turkey gobble and some noticable frame vibration.
    The first 30 mins of the ride, the brakes are fine: no squeal no gobble. Part of me is assuming it's caused from overheating. Any ideas?
    Nobody gives a s#$t you singlespeed.
    rockhound
    Check to see if you have play in the hub.
    Rotors get tweaked too if you brake hard through a turn and there is play in the hub. So you might have to true your rotor.
    But I think you are right about not having the rotor centered in the caliper. A little offset would cause the squealing and gobbling too. Hard to keep the rotor centered if there is play in the hub.
