Hydraulic brake line pressure??- Mtbr.com
Results 1 to 9 of 9
    Hey all!
    I've been searching like mad for any information (including calling tech support for multiple manufacturers) about what kind of pressure that the master cylinders and brake lines on hydraulic brake systems operate at or are designed for. I'd appreciate ANYTHING for ANY make/model if you have the data.
    not sure what you mean - max. pressure that is applied at lever/master cylinder? Open system is at atmospheric pressure, by definition.
    rshalit: Thanks, but I'm really more interested on the closed system...And yes, the max pressure applied at the master cylinder would be exactly what I'm looking for.
    Never trust a fart
    Reputation: frdfandc's Avatar
    The answer is 42. It is always 42.
    Or a lot plus 10.
    Or eleventy.
    Quote Originally Posted by frdfandc
    Or a lot plus 10.
    Or eleventy.
    I think he is looking for a serious answer. Don't throw out random numbers like that. That's not nice. And it's not 42.
    It's "pie are square".
    Stiff yet compliant
    Reputation: Moustache rider's Avatar
    The pressure developed will depend on how hard you squeeze the brake lever and will have a huge range.
    If you knew what the master cylinder bore was you could figure out line pressure for a given lever squeeze force. However, I have never seen that information published.
    Mar 2011
    I'd think max pressure would be mechanical ratio x lever pressure/mc bore area?
    So in the hayes stroker trails, - lever mech ratio is approx 5.33:1
    The bikeradar brake test went to 150nm, so we can use that.
    I think the stroker bore is 10mm, thought I read that somewhere, seems about right, I'll use it.
    EDIT: 150x5.33= 799.5
    10mm bore = 5mm^2*pi=78.5mm^2
    799.5N/78.5mm^2= 10.18MPa, which converts to 1476psi.
    I'm not 100% on my math/unit measurements, but this sounds abouts right.
    Yeroon
    Quote Originally Posted by The_Rizzle
    Yeroon
    Math is okay but the unit of force must be Newtons not Newton meters (that is a torque)...
    So force X multiplier/area = pressure
    If however the input is in Newton meters...then you would have to divide by the lever arm and the area to get pressure.
    Mar 2011
    correct - I was thinking they had written Nm, but they were using Newtons.
    The 5.33 mech ratio was found measuring a set, and is the farthest you could put a finger on the lever, ala single finger braking.
    http://www.bikeradar.com/gear/articl...-brakes-24345/
    The 150N might not be max lever pressure, but its probably pretty close to the limit.
