how to replace mountain bike mechanical brake pads- Mtbr.com
    Jun 2010
    I have tried to replace the brakes pads on mountain bike but I couldnt...
    I checked some videos on youtube but the brake is different
    if any body knows, thank you ..
    my bike has Brakeset Shimano M415, mechanical disc w/Shimano EF50 levers
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    they should just tug right out w/ a pair of pliers
    Honestly... ahh I give up
    Jul 2003
    Should be quite simple....
    remove the wheel, open up the inboard pad adjuster all the way. With a pair of smaller needle nosed pliers bend the open end of the split pin goes through the top of the caliper and the tabs on the brake pads and return spring closed and then remove it from the caliper. Once the pin is removed you can use the same pliers to reach in and gently press the pads together from the rotor opening end of the caliper. Once compressed together pull down and out. The pads should come free of the caliper fairly easily. Next make a brake pad sandwich with the inboard and outboard pad and the return spring in the middle with the new pads. Slide them in place, insert the new split pin that should have come with the new pads. Install the wheel, make pad spacing adjustments as needed and your done. If you need help or pictures to go with it, go here, http://techdocs.shimano.com/media/te...9830604364.pdf
    Good Dirt
    Jun 2010
    thank you for the inf...
