how to cut Shimano hydro lines- Mtbr.com
Results 1 to 7 of 7
    Just installed Shimano Brake System. Lines are too long front and back. How do I go about cutting them down ? No directions w/ the brakes.
    PS: Look and feel great so far.
    All about the ride
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    you need a new olive and insert per line..... if you are careful you can cut the line without bleeding the brakes.
    you have to put the lever parallel to the ground...undo the screw and move it, pull a bit to disconnect the line...don't wiggle much so that you don't lose oil.... cut the line... position the olive about 4mm from the end of the line and insert the "insert".... if you managed not to drop much oil, you should be able to put it together and go on your merry way.
    If you don't mind bleeding...just remove the oil before..and then fill the system up... I usually do it like this...
    mmm
    That was easy. Thanks ! How nice is mineral oil to work with. Should have done this Hayes to Shimano a while ago.
    All about the ride
    glad you got it done... I have to cut the lines on my new XTs one of these days just haven't taken the time...
    Reputation: carl1266's Avatar
    Quote Originally Posted by crisillo
    What do you use to cut the hose or what is the best tool to cut it?
    Meh.
    Reputation: XSL_WiLL's Avatar
    There are some hose cutters out there. I've been fine with using a sharp razor blade.
    Quote Originally Posted by carl1266
    I just use a blade while holding the hose with the yellow blocks
