how can i fix my brake cables...help- Mtbr.com
Results 1 to 10 of 10
    Reputation: justbuster69's Avatar
    ok guys,i need your help.yesterday i bought a pair of hope tech m4's with the braided cables.i didnt notice while the brakes were being placed on my bike that the cables looks "twisty"i tried removing the lever from the hbar and uncoiling it but it still looks like it wants to coil.any suggestion on what i can do?
    Come see me after class
    Dec 2005
    are you sure it's not just the steel braiding that's making them look coiled? post a pic.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by justbuster69
    Hydro brakes do not use cables
    mtbtires.com
    Dec 2005
    if you want to argue semantics, they're hydraulic brakes, not hydro brakes.
    Singletracker
    Jun 2005
    Quote Originally Posted by alexrex20
    at you.
    I suppose the OP means brake hose. IF uncoiled and untwisted as much as possible they will sorted them selves out with time.. Nothing else you can do.
    thanks,here is a picture.and yes i was referring to the hose
    Singletracker
    Jun 2005
    picture?
    ah,got to make it work this time.heres how the HOSE looks like
    Reputation: sanjuro's Avatar
    Sep 2004
    There's nothing wrong. Steel braided hoses are stiffer than plastic, so they tend to bend in surprising ways.
    The only problem is the hoses are too long. If you have the tools to make a clean cut and you're willing to rebleed, you can shorten the rear hose. I would probably cut down the derailleur housing as well.
    But it simply a cosmetic thing. You can leave it long and the brakes work fine.
    Quote Originally Posted by sanjuro
    thanks sanjuro--i might bring it to my LBS and have it shortened and rebleed.thanks so much for the advice
