hose swap- Mtbr.com
Results 1 to 3 of 3
Thread: hose swap
    hose swap
    Wondering if anyone has used Avid hose on Formula Oro's. I can't find any id/od info on either one anywhere.
    When you buy 'hose', you actually get one of the ends (usually the caliper) with all the fittings too. This is because the fittings are crimped on and non replaceable. I'm not 100% sure, but I don't believe the fitting for any 1 disc manufacturer are the same.
    It's true that they usually come with one end outfitted, but both ends on Formula's use the same fittings. What I am wondering about, is if the interior and exterior diameter of the two hoses are the same. The factory crimped end is a non issue, if what you need is raw hose.
