    Music & Bikes
    Reputation: fokof's Avatar
    Hope mono mini & noise
    I have Hope MM both frt & rear , the front disk is a costom Hope 160mm 4 bolts disk. In dry conditions , at low speeds , it has that high pitch squeal ( 10kHz ) , under heavy rain , it sounds like Brittney Spears without pitch correction ( really bad! ).
    In the back , I have a Gelfer disk fitted on my Rohloff speedhub , and it's as silent as possible , dry , pourring rain , 3 feet of mud , always silent.
    All with original pads.
    So I thought it was related to disks, but I had to remove my fork for repair , put another fork on my bike , dead silence............ Squeals under rain , but lot more silent.
    So there is lots of factors with noise & disk brake , not only pad/disk/caliper , I'm curious to hear what it's gonna be with my fork on.......
    "There is a big difference between kneeling down and bending over" -FZ
    Reputation: misctwo's Avatar
    Quote Originally Posted by fokof
    hmm, either a squeal, shudder, howl, or any combination of the three. you'll hate it.
    I personally prefer the soothing sounds of turkey gobble that's so endearing to the Juicy brakes.
    Music & Bikes
    I saw in other posts that you had bad experience with Hope & noise , that's too bad.
    I came to the conclusion that it's a setup thing since I had the same caliper/disk combo , one noisy , one silent , but on different forks.
    Should be a kind of "facing" question.
    Music & Bikes
    Just received my "repaired" fork wich in fact , is a brand new one.
    Installed everything , and after two weeks , it's DEAD silent.
    I came to the conclusion that the original fork on my bike was not "faced"
    I have a pair of light & powerfull & silent disk brakes
