Hope floating rotors with Magura Martas- Mtbr.com
Results 1 to 7 of 7
    dcb
    dcb is offline
    Does anyone know if hope floating rotors will work with Marta calipers? I've done a search but cannot find any threads on the subject.
    I do know that the floating rotors will not work with Hayes HFX 9's in case anyone was wondering about that.
    Reputation: DCRick's Avatar
    what about avid j5's ? ?
    laser guided democracy
    Not sure about the Martas, but i know they don't work with '06 Louise FR- the rivets hit the bottom of the caliper, if the Marta is smaller then it may work. Just order some and carefully try the disc, use three old rotor bolts and dont damage the packaging, then send them back if not.
    They could be made to work with the J5.You will have to file a bit of material off the adaptor to clear the rivets.
    You can't make a racehorse out of a donkey, but you can make a fast donkey.
    dcb
    dcb is offline
    I read a post in another forum that said that they will not work with the Marta calipers.
    what dya mean by fiel some off, surely this would bring it closer to the rivets ?
    If you remove some material from the adaptor then the gap between the adaptor and the disc becomes larger
    oh, do you mean file some off from the side ? i thought you meant from the top !
