Results 1 to 10 of 10
Thread: holes in rotor.
    Reputation: Justin Credible's Avatar
    holes in rotor.
    Ok so I have tried to find out what the diiference in the hole in the rotors are. I like the ones with less material and bigger holes. What the difference in performance with the ones with smaller holes or barely any holes? Im building a wheelset and I like the looks of the hope saw blade but Im not an expert on these. my other choice would be like a Avid clean sweep. what to do, what to do. Thanks for your input
    60% of the time ......it works all the time
    Holes are mainly for reducing weight. They also help to churn up the air and increase cooling. On the downside, they reduce the amount of material for the pads to grab, and reducing the rotor mass reduces the amount of metal to absorb heat (heat sink).
    In general, the light ones with big holes work fine, so the disadvantages aren't much to be concerned about, but I have read some people claim decreased stopping power of super light rotors.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Another factor to consider is what caliper you'll be using . . .
    namagomi
    Reputation: electrik's Avatar
    They're just speed holes... The more holes on the rotor the faster you go!!
    I think larger holes wear pads faster.
    jx
    Reputation: Tim-H's Avatar
    ^ They probably do. They'll create more scraping on the pad surface and clean the pads as they wear, also clearing any brake dust from the surface and preventing glazing. Like rubbing cheese against a grater vs a piece of sheet metal.
    I see. I don't want anything super light. I just wasn't sure if the ones with larger holes would decrease stopping power. There are just so many voices. What do you guys run?
    I have G2 rear G3 front. There's a point where you'll see diminishing returns and even negative impact on braking performance. I wouldn't run a solid rotor, like the roundagon. It would heat up way too much and not clean the pads well enough.
    Quote Originally Posted by smilinsteve View Post
    they do reduce the amount of disc rotor for the pads to grab on initial contact. but they provide more friction for the pads to slow the rotor down which in turn slows the bike down.
    the disadvantage of the drilled holes and slots in bike brakes is that the weaken the rotor strength so they will be susceptible to warping or bending. if you had a heavy object like a car brake disc, this would be more of an issue as you will be able to feel it in the pedal. also, on a car, drilled rotors can crack due to the immense pressure from the calipers and the heat created from the weight of the car. bicycles are much lighter and you are not on the brakes for as long as in a car so heat is not as much as an issue. (motorcycles are the same. hence why none of them have ceramic discs.)
    Other than roundagons which are mostly solid, pretty much all rotors are drilled and or slotted, so I don't know exactly what the OP is trying to decide. If you look at a bunch of different rotors, I don't think you can tell by looking at them which ones will work the best. There are some superlight rotors, like Aishima, that have so little brake surface you have to wonder how well they will work. I've read mixed reviews on those type. Your basic Avid, Hayes, Hope, Formula, etc probably have some performance differences between them, but they are probably small, and I don't know how you could predict anything about them without head to head testing.
  1. Easton XC One - stripped rotor bolt holes / replacement hub
    By flipsidem in forum Wheels and Tires
    Last Post: 04-12-2011, 09:58 PM
  2. Stripped rotor bolt holes
    By GhisalloWheels in forum Brake Time
    Last Post: 04-17-2008, 07:43 AM
  3. Stripped Threads to Rotor Bolt Holes
    By kiwi_1234 in forum Brake Time
    Last Post: 09-04-2007, 05:18 AM
  4. Comparing rotor designs, holes ?
    By keen in forum Brake Time
    Last Post: 08-06-2006, 10:07 PM
  5. Drilling bigger holes in brake rotor?
    By loosch in forum Weight Weenies
    Last Post: 11-27-2005, 01:40 PM
