Help! How much do brakes weigh?- Mtbr.com
Results 1 to 3 of 3
    Reputation: ppfeifer's Avatar
    Back ground: I need another set of brakes but I've got a maximum budget of $150 per brake. These brakes are going on my Jet9 cross country rig, so weight is a factor. Unfortunately, I can't figure out how much these brake systems weigh because there are so many conflicting numbers out there. The recent BB7 post that listed all the different component weights is fantastic.
    Question: Can you please help me out with actual weights on the following systems? If you can break it down into front, rear, rotor, and component weight that would amazing. Please don't refer me to manufacturer web sites b/c I've already been there many times.
    Hayes Stroker-
    Trail
    Gram
    Formula-
    RX
    Shimano-
    XT
    SLX
    Thanks I'm buying a scale very soon and will return the favor.
    Reputation: bikerboyj17's Avatar
    Actual weight of stroker grams is in here: http://www.gramslightbikes.com/2009/...mpessions.html
    bikerboyj17- Dude! That's what I'm talking about. Thanks.
