Hayes Stroker Ryde help needed......- Mtbr.com
Results 1 to 3 of 3
    Hi all,
    I recently had a Stroker Ryde installed on the back of my bike. I have been on 2 rides with it so far. Today I noticed when I hit the brakes it squeaked. Is it typical for them to squeak occasionally? If not, what do you think needs to be done? I know this is a newbie question, just getting used to disc brakes, I have been on shoes and just switched to discs.
    brakes make noise all the time, as long as they are stopping fine and the noise isn't constant i wouldn't worry about it.
    Squeek occasionally?!?
    You're lucky it is occasional.
    Actually when you heat them up and then stop and let them cool down they tend to squeal a bit the next couple times you use them before they get quite again.
