hayes sole question- Mtbr.com
Results 1 to 3 of 3
    hayes sole question
    my brakes have never been bleed and its been about 5 years and the front works perfect. my rear break is feeling spongy. why is this? it is constantly like this whether i pump them or not. why do they not feel the same?
    Reputation: mitzikatzi's Avatar
    Because the back brakes need a service. Bleed them as a minimum.
    You have either "lost" some brake fluid or more likely you have air in the system. This happens to brakes. More unlikely is the hose is stretching under pressure.
    If you pay someone to service your brakes or you buy a bleed kit and do it yourself. If the calipers need a rebuild kit. It may just be cheaper to buy new brakes. I have seen at CRC Juicy 3's for about $80 (considering you get a new rotor and new pads as part of the package). If your bike is 5 years old you may well need new pads and rotors as well.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    A new brake system would be the best thing if in the budget. If not could be pads as mentioned, adjustment or and fluid. The fluid should be replaced about once a year, this never happens in the real world though.
    http://www.hayesdiscbrake.com/wp-con...WebEnglish.pdf
    http://www.spadout.com/c/hydraulic-disc-brake-system/
    Formotion Products
    http://www.formot
