Hayes malfunction, bleed does not fix- Mtbr.com
Results 1 to 2 of 2
    I'm how far behind?
    Reputation: Soloracer's Avatar
    New question here. Hayes malfunction, bleed does not fix
    I have 03 Hayes HFX Mag brakes. After a crash the front line was damaged so I took it in to the shop to have the cable replaced. After 5 bleeds and every trick the mechanic knew, the brakes barely work. With the lever depressed all the way, they will engage but not to any acceptable amount. We also slipped in new pads just in case and no improvement was seen. Any suggestions??
    Jim
    The Master Cylinder could be damaged
    Quote Originally Posted by Soloracer
    Jim
    If the front line was damaged where it connects to the brake lever assembly you could have a damaged master cylinder or the master cylinder reservoir bladder could be dislodged or torn and allowing air in.
    Erik,
    Balle Racing
    www.balleracing.com
  1. Replies: 7
    Last Post: 01-26-2004, 09:07 PM
  2. Hayes w/ Klein 01' and Black 02'
    By wyrm in forum Brake Time
    Last Post: 01-23-2004, 04:33 PM
  3. Hayes Lever Problems
    By Justintime in forum Brake Time
    Last Post: 01-22-2004, 06:58 PM
  4. Hope Mini v. Hayes HFX-9 v. avid cable?
    By MrXC in forum Brake Time
    Last Post: 01-21-2004, 06:18 PM
  5. Replies: 8
    Last Post: 01-20-2004, 03:20 PM
