hayes mag G1 caliper- Mtbr.com
Results 1 to 3 of 3
    aka Dick Dangle
    Reputation: it hurts's Avatar
    Are Hayes Mags With the G1 caliper any good,how much do they differ from the G2. thanks
    Meh.
    Reputation: XSL_WiLL's Avatar
    G1 is the previous generation. G2 is the current generation. The new G2 caliper has a "cut-out" in the back. Allows for better heat dissipation, and it's easier to visually allign the caliper. The G1 caliper uses a banjo fitting, the G2 uses an in-line, though it can be made to use a banjo).
    The G1 works just fine.
    Lets see- over six years on my Mag set with G1 calipers and not a single issue. I would say they work just fine.
    I bike; therefore, I work
