hayes el camino bleed question- Mtbr.com
Results 1 to 9 of 9
    Wandervans
    Reputation: smilycook's Avatar
    I am attempting to bleed my el camino brakes and now having much luck. I have the master cylinder at the highest point and the bleed screw off. And the hook up the bottle onto the piston and then open the valve. When I squeeze the bottle I can't seem to force any fluid in and no fluid comes out at the master cylinder. What am I missing?
    Chris
    Live to ride!
    18 Cannondale Jekyll Carbon
    16 Diamond Back DB8
    https://www.facebook.com/wandervans
    wandervans.com
    Meh.
    Reputation: XSL_WiLL's Avatar
    Make sure that the knob is not dialed all the way our or all the way in.
    Forget the squeeze bottle. Use a syringe.
    Adjust the lever reach screw in about half way.
    Feb 2007
    You may want to try Park Tools' instructions; they are pretty good and very easy to follow.
    Good luck,
    Here is the link:
    http://www.parktool.com/repair/readhowto.asp?id=138
    DNW
    DNW is offline
    Reputation: DNW's Avatar
    Mar 2006
    Quote Originally Posted by mtbsince1981
    I spent three days trying to figure out why I couldn't force fluid through my El Caminos. This was exactly the problem.
    Glad I could help.
    Randy
    Wandervans
    finally got it too work
    well I tried the knob and the lever adjust with still no luck. Then I decided to try the technique from the avid thread to take the brakes off of the bike and then mount the lever in a vise and put the caliper on the ground. Placed the catch bottle on the bottom and then forced fluid from the top. After a couple good squezes from the bottle at the lever I had fluid coming out at the caliper. Let a bunch of fluid run throught then closed the system up. Works great now!!
    Live to ride!
    16 Diamond Back DB8
    wandervans.com
    So you were attempting to push air bubbles downward? If so, there is still air in the brake.
    Wandervans
    I ran at least 10oz of brake fluid throught the lines into the catch bottle on the bottom and squeezed the lever too while pushing the fluid. The tube at the caliper was full of fluid when I tightened the valve. Do you still think I have air? They seem to work well.
    Chris
    Live to ride!
    16 Diamond Back DB8
    wandervans.com
