Results 1 to 2 of 2
    Reputation: letsgoride's Avatar
    Hayes Bleed - Need help!
    Doing a bleed and can't get the brake fluid to move up the tube. Instead it leaks out around the master seal and near the opening, am I missing something? Is this the wrong adapter for this brake?
    Dude! Easy one here. The T10 screw you removed is just to hold down the reservoir cap. The plug next to it with the little flap is what you need to remove so you can insert the fitting for your over flow bottle. Put that screw back in and tighten it lightly, ie not to a dead stop. Just enough so you feel it. Pull the plug, insert bleed fitting, opush the fluid on up from the caliper, and ife will be cherries after that !
    You are not what you own.
