Hayes 22mm disc brake- Mtbr.com
Results 1 to 7 of 7
    Reputation: schwinnguy74's Avatar
    I just purchased one for my Schwinn homegrown will a shimano lever work with it just as the lever is new thanks.
    Meh.
    Reputation: XSL_WiLL's Avatar
    No. Different fluid type.
    What fluid does hayes use also will these pads work http://www.chainreactioncycles.com/M...x?ModelID=1235
    Reputation: GrampBredo's Avatar
    That's a darn small rotor, mine are 203mm.
    Hayes use DOT 3 or 4 fluid (doesn't matter, 3's cheaper). Fluid can be found at any auto store, even gas stations. Shimano uses mineral oil.
    What is the model name of the brakes? Then I can tell you if those pads will work.
    I don't know the model number but this is the one I got http://saltlakecity.craigslist.org/bik/1461970341.html
    Meh.
    22mm is not the rotor size. That's under an inch. 22mm is the caliper mount spacing. I hope you have a rear end that uses a 22mm mount... as this is no longer a common size.
    IIRC, those pads would work.
    Hayes uses glycol based DOT fluid. Shimano uses mineral oil.
    Yes I have a 2000 Schwinn homegrown thats takes that brake.
