Has anyone tried un-branded brake pads from Ebay or Alibaba?- Mtbr.com
Results 1 to 8 of 8
    Looking for Code pads, there are many un-branded on those sites. Anyone tried them and can give feedback?
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    Sure, I've been running a set of the cheapest ebay ones I could find on a bike right now, probably about 30 hours on them for xc use. They seem to work fine. The resin non finned for Shimano, I think they were $2 shipped for the pair.
    This low price makes sense to me because the construction is basic and the materials are pennies. For a chunk of ceramic that you smash into a chunk of steel, the big companies sure do charge for them.
    Another cheap component I'm using is the $10 BH90 brake hose knockoff. It's literally indistinguishable from the $30 Shimano one.
    WillWorkForTrail
    Jun 2012
    Figure out how much you'll be paying all in (shipping, etc) for those off brand pads and then see what you can get some truckerco pads for. If it's a couple bucks difference, I'd get the truckerco just so you know what you have. But that's just me.
    mbtr member
    Reputation: scottzg's Avatar
    I bought a set of truckerco pads, then bought a small mountain of them. I like them as much as i like sintered shimano pads.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Unbranded eBay specials, if they fail you may go to hospital or dentist.
    Sounds like a great plan to save a few bucks.
    At least stick to disco or truckerco.
    Reputation: PuddleDuck's Avatar
    I wouldn't. The risk is too high. I'd trust an inexpensive brand that had good reviews, but not unbranded pads.
    Reputation: whtdel's Avatar
    I tested various (ebay) cheap brake pads in the last 2 years, all were Magura MT's, either the small, 4-piston ones, or the 2 pistons (I ride the MT-trail model).
    The best I've found (4-pistons models) so far were the gold semi-metallic, sold through Bikein e-seller. They proved to be silent, offered great power and modulation. They lasted the whole season (45km vertical climbing/descending in total, trail riding), but they wore down my rotor (front) to 1.77 mm (from 2.0mm) during that period of time. Some could say ... what you save on pads, you pay on rotors.
    Also, I tested a 2 piston-model pad set, this one fully metallic (black one). Unfortunately, they stayed noisy (high pitch metallic noise), and glazed after a few rides. The pad compound is very hard (difficult to sand off the glazed surface). I ditched them.
    Next test are going to be the ceramic compound (red one).
    This said, I know Magura (and probably Shimano), advice against any metallic content in the pads, since they conduct heat and may bring the oil to boiling point. If I were to live on the West Coast, I'd probably stay away from anything but resin pads, but my riding area is quite flat compare to Colorado/BC.
    Reputation: Timothy G. Parrish's Avatar
    Apr 2014
    One issue you need to be aware of with cheaper pads: the way the pad material is bonded to the backing plate. Some brands have holes in the plate and pad material fills in the hole to bond. These are good. Others have raised pegs and the material bonds to those. When the pad material wears down, these pegs don't and will eat into your rotors if you aren't careful. I found out the hard way. First picture is cheapo, second picture is Avid.
  1. Alibaba.com
    By Enduro14 in forum Bike and Frame discussion
    Last Post: 02-09-2017, 05:42 PM
  2. Alibaba Specials ;)
    By maynard in forum 27.5
    Last Post: 05-29-2013, 07:57 PM
  3. Buying Alibaba or Aliexpress
    By brmeyer135 in forum 29er Components
    Last Post: 03-27-2013, 03:35 AM
  4. Alibaba.com buyer beware
    By tsull247 in forum Where are the Best Deals?
    Last Post: 02-22-2011, 03:00 PM
  5. Has anyone tried those OBE pads on eBay?
    By cgrocho in forum Brake Time
    Last Post: 01-19-2009, 12:50 AM
Members who have read this thread: 69
