Guide R and RS use same brake lever?- Mtbr.com
Results 1 to 3 of 3
    Jan 2016
    I have the SRAM Guide R brakes and bent a lever blade during a crash. I see the "RS" blade replacement on eBay but not the "R". Does anyone know if the R and RS use the same lever blade? I don't care about the other internals in the kit... just need the actual lever. The Guides I have were made in 2014-2015 time frame. Thanks!!
    Reputation: Steel Calf's Avatar
    Feb 2010
    Judging by the pictures in this thread I think the levers are interchangeable as they both have the same bearing and the SwingLink mechanism does seem to be independent from the lever
    http://forums.mtbr.com/brake-time/sr...ke-934259.html
    but I'd rather double check that by taking a look at Sram Tech Docs or calling up Sram directly
    Jan 2016
    Thanks for reply. I think they are the same. The parts manual product number is different but the part kit includes all internals which may be different but I don't care about the other internals being different. Apparently can't just order the blade as it doesn't have own part number....
  1. Replies: 1
    Last Post: 09-20-2015, 11:48 AM
  2. Replies: 9
    Last Post: 06-17-2015, 02:56 PM
  3. elixer brake lever position, vs shift lever
    By thecanoe in forum Brake Time
    Last Post: 10-25-2012, 04:04 PM
  4. shift lever/brake lever position
    By thecanoe in forum General Discussion
    Last Post: 02-11-2012, 06:52 PM
  5. Replies: 1
    Last Post: 10-27-2011, 04:51 PM
