Formula Rotors with Avid Elixir CR- Mtbr.com
Results 1 to 2 of 2
    Where can you get a front, post mount adapter that will let you use the formula R1 (??) 180mm rotor with Avid Elixir CR calipers (currently using 185mm rotors)?
    The adapters are all standard....so any 180mm adapter will work. I think shimano uses 180mm rotors.
