Formula 140mm rotor adaptor options?- Mtbr.com
Results 1 to 9 of 9
    Im using formula k24s and want to go down to a 140mm rear rotor. anybody have any experience with this? particularly, what are my options for adaptors? I have an avid 160mm rear adaptor that looks like it may work for a 140mm rotor once the spacers are removed. any ideas? appreciate the help.
    aka bOb
    Reputation: bdundee's Avatar
    I use a Shimano front 160mm on the rear for a 140mm on my RX's. The Avid one I tried to use had clearance issues and it would've needed filing. Do a mock set up before tighting the bolts to make sure the caliper and adaptor aren't making contact where they are not suposed too.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by richhoare
    Any 160mm front bracket is also a 140mm rear bracket.
    mtbtires.com
    aka bOb
    Quote Originally Posted by shiggy
    True but not all adapters are compatible with all calipers.
    160mm front will not work
    160mm front will not work with R1 brakes may be a 180mm front may get you to 140 rear.
    I would call Formula
    there calipers are not the same as other manufacturers
    aka bOb
    Quote Originally Posted by Big Foot
    Really? That's odd I am running 160mm adapter with 140mm rear on RX's.
    Edit: Shimano adapter
    Attached Thumbnails Attached Thumbnails Formula 140mm rotor adaptor options?-rear-140mm.jpg
    Reputation: k1lluaA's Avatar
    Not true....atleast for hayes adapters...guys at hayes tech told me specifically not to use this method of adapter switching.. just be careful cause it could **** your warranty or really your brakes if your not careful
    2008 Kona Caldera
    "Today I saw my own son use a bicycle as a weapon....
    I seriously thought he was going to rape me"
    Dec 1998
    Quote Originally Posted by k1lluaA
    Warranty-speak. The bracket spec is the same.
    Avid shows the 160 front as also being a 140 rear as do most other brands
    mtbtires.com
    Dec 1998
    All current Formula calipers are post mount. Any IS bracket works as long as the caliper clears.
    mtbtires.com
