Fixing a scarred rotor- Mtbr.com
Results 1 to 8 of 8
    My own stupid fault- put organic pads in instead of sintered on a wet Yorkshire Dales ride. They wore out 20 miles into the ride and now my rotor has some not insignificant gouges and scrapes
    Any tips for repairing the rotor apart from attackng it with a Dremel?!
    Is it even worth bothering to fix considering discobrakes.com sell 180mm rotors at 13?
    ...idios...
    Reputation: SteveUK's Avatar
    Pics?
    Diogenes
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by RicB
    Replace it if it bothers you. Repairing is not feasible. At best, you would have thick and thin spots that would cause a surging feel.
    mtbtires.com
    2010 RockHopper Comp Disc
    Replace pads and see how it goes. The rougher the rotor is the better your braking power.
    Been there done that....
    1 Best way get a flat file and carefully work your way around the rotor (takes care of the little ridge where the pad ended.
    2 Quicker get an angle grinder with a flap pad, very gently go over the whole rotor, careful to move around alot.
    3 Easiest get some fine sand paper pinch it between your fingers and rotate the bike wheel let your fingers rest up on the caliper...
    4 Lots of patience, glue the sand paper to some pads and insert in the caliper spin wheel...
    Pick 3 get some new pads, if you get squealing or poor braking move on from there.
    Quote Originally Posted by shiggy
    BS not true at all, thick and thin spots have never been my problem, and I have fixed about 5 cooked, and scrapped rotors.
    replace... trying to fix them isn't worth the time you would invest, only to have them possibly not work...
    I quite enjoy fixing things, and it gives me something to do whilst the wife watches Strictly!
    Great suggestions there Jeff, thanks
    Will sort some pics later and let you know how it goes
