final straw with Hayes. Please help- Mtbr.com
Results 1 to 2 of 2
    My Hayes Mag discs are driving me crazy. Here's the deal.
    For the past 5 rides I've been on the pavement just dinkin' around. Brakes were fine. Although I've had many issues with them over the past year (rebleeding, loss of feel at lever, air bubbles) they totally went away on a 2 hour rough and bumpy ride yesterday; probably my first true "mtb ride" on this set in 4 months. No feel. No modulation. No brakes. It's like the jarring and jumping effected them.
    Now when I pull the levers they go back to the bars and I can hear an "empty" squishing sound from the master cylinder. I've become quite the expert at bleeding them, and the levers feel perfect afterward, but they end up back at crap, hitting the bars, when I go on trails.
    I don't see any leaks. Could it be my tiny philips screw/o-ring in the master cylinder is sucking in air? Any ideas?
    Reputation: skywaybuzz's Avatar
    Sounds like your loosing fluid. Maybe new lines. Never seen the bleed screw go bad even when I thought it was striped. If the bleed screw isn't leaking fluid then it should be ok
  1. Replies: 1
    Last Post: 02-08-2005, 12:39 AM
  2. Hayes HFX 9 XC's vs Avid Mechs
    By Max99 in forum Brake Time
    Last Post: 01-04-2005, 03:10 PM
  3. 2000AD Hayes 22mm Ramble
    By Mr Fuzznel in forum Brake Time
    Last Post: 12-30-2004, 09:30 AM
  4. Romic or Swinger 4way coil for 5 Spot
    By Alpenglow in forum Turner
    Last Post: 05-19-2004, 06:20 PM
  5. Hayes MX1 vs. MX2?
    By czardonic in forum Brake Time
    Last Post: 03-26-2004, 02:30 PM
