Elixir Brake Bleed video- Mtbr.com
Results 1 to 6 of 6
    Thought I'd post this up for all Elixir owners looking for info on how to properly bleed their brakes.
    <object width='500' height='287'><param name='allowFullScreen' value='true' /><param name='AllowScriptAccess' value='always' /><param name='movie' value='http://www.pinkbike.com/v/134884' /><embed src='http://www.pinkbike.com/v/134884' type='application/x-shockwave-flash' width='500' height='287' allowFullScreen='true' AllowScriptAccess='always' /></embed></object>
    Old man on a bike
    That's a little different from the last Avid video on the subject I saw. Not too impressed about when he tells you the pad contact adjuster should be dialed all the way next to the body, though. Will try this procedure on the next bleed...
    suum quique
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Quote Originally Posted by Bikinfoolferlife
    Bubbles rise his master is down.
    Formotion Products
    http://www.formot
    Wait, if you pull on the plunger to de-gas the fluid and let the plunger go back, all the gas reincorporates itself back into he fluid.
    Just try that with a syringe and water. Plug the end, pull on the plunger and you will see it "boil", now release the plunger so it goes back to normal, all the air that "boiled" out of the water is now gone. Where did it go? Well, it went back into the water.
    Old man on a bike
    Quote Originally Posted by dogonfr
    So yer saying my miniscule experience didn't spot an obvious goof in the vid, eh? One reason I don't like vids, now if I want to go back and see what you mean I'll have to watch this doofus again. Does this have something to do with the vid being copied from pinkbike?
    suum quique
    Jan 2005
    Nope just agreeing this video is lame so dont wast your time watching goofball again.
    Formotion Products
    http://www.formot
