disk brake help- Mtbr.com
Results 1 to 5 of 5
Thread: disk brake help
    disk brake help
    I recently converted my xc racer to avid Juicy 7's from v- brakes and while the front is fine, I'm having trouble skiding the rear tire in race situations when I don't want to and I can make this happen with 1 finger. Soon after I installed them I started to encounter rear brake noise and on the advice of another racer traded one of the stock pads for a Galfer semi-metalic. This cured the noise and vibration but I simply have too much power. I'm running a 160mm rotor. How do I make these brakes less powerful?
    Reputation: EliM's Avatar
    Give them to me?
    Well, I was just riding along when...
    Reputation: Hardtails Are Better's Avatar
    May 2005
    140mm rear rotor.
    Aug 2005
    suggestions
    shift your weight back. or swap to grippier tires. or use more front brake and less rear.
    how large of a change would a 140 mm rotor bring?
