Disc break in- Mtbr.com
Results 1 to 6 of 6
Thread: Disc break in
    Disc break in
    I'm running stock shimano disc's on my 09 Kona Cinder cone. I'm having the hardest time centering the rotor in in the caliper. And even when i do get it to where it's someone centered, after an hour so of riding it starts making noise like the rotors bent (but it isn't).
    anyone have a similar problem and what was your fix. My next guess is that the pads are unevenly worn?
    T.W.O.
    Reputation: mimi1885's Avatar
    Or may be fork/frame flex.
    Linoleum Knife
    Reputation: forkboy's Avatar
    Quote Originally Posted by WaTyme
    Sticky piston. See other threads...
    Check the bearings in the hub. loose/worn bearings will give these symptoms as well.
    Awesome, i will check into all of this. Thank you.
    MEGALOMANIAC
    Reputation: Hawgzilla's Avatar
    Nov 2008
    Make sure the axle/quick release is very tight.
    If the pads are well used, get new pads.
    It's common for new brakes to squeal and or groan. It should deminish as the pads and rotors wear into eachother. It could take several long rides...
    life is... "All About Bikes"...
