Disc Brake Tabs for Traveling- Mtbr.com
Results 1 to 7 of 7
    Freeriding Feline
    Reputation: SuperKat's Avatar
    Mar 2005
    New question here. Disc Brake Tabs for Traveling
    Anyone know where I can get tabs to use when the wheels are off the bike for traveling, in case the brake levers get compressed?
    Or is cardboard my best bet?
    "If you give up your dream, you die."
    Twitter - KIKat1029
    Reputation: in the trees's Avatar
    Mar 2005
    I know that Hayes and Shimano have specific models for their brakes. Little plastic clips that insert into the caliper to prevent the pads from moving wheel the wheel/rotor is off the bike. Your LBS should have a bunch of them kicking around. And I think I have both Hayes and Shimano ones if you strikeout.
    toby
    Meh.
    Reputation: XSL_WiLL's Avatar
    Stop by your LBS, they usually have tons of them sitting around - as mentioned, they are usually specific to the caliper. If you're in a pinch, use a folded up piece of cardboard and jam it between the pads.
    Freeriding Feline
    Mar 2005
    Thanks guys.
    Actually, that's exactly what I need...Hayes and Shimano. 2 different Nomads being packed up for Moab in April.
    I think we're going to rent the travel cases from our LBS so hopefully they can hook it up!
    Thanks again,
    Kat
    Twitter - KIKat1029
    Reputation: mtnbiker1973's Avatar
    I bought some hayes ones for my Hope brakes. They were $1.00 each....
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    I use cardboard held in place by a rubber band.
    My video techniques can be found in this thread.
    mbtr member
    Reputation: scottzg's Avatar
    i chopped up a 160mm rotor with an angle grinder. The ones provided by the brake manufacturers always push my pistons back in so i have to readjust them.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
