Cross Post: Noodle Degree?- Mtbr.com
    Reputation: Casual Observer's Avatar
    Anybody know what difference the noodle degree has. I found a cheap pair of brakes on Cambria, but it gives me noodle degree (90 or 130) instead of Front or Rear. Does the degree have to do with whether they are for the front or rear?
    Tad
    Tad is offline
    enormous member
    90 degree noodles are for the rear and front if you use the right brake lever to activate the front. 130 degrees is for the front if you activate from the left brake lever. I THINK...
    Regardless, noodles are cheap and can be bought separately.
    Crank monkey
    Reputation: Smytty's Avatar
    I'm no expert, but...
    Have a look at your cable routing. I just put new noodles on my wife's bike, and used a 130 on the rear, and 90 on the front, but I went purely by which would give the smoothest cable routing.
    Cheers,
    Smytty
    On MTBR hiatus :(
    I like 130 rear...
    ...for heel clearance. Performance wise doesn't make a difference, so use what makes for the best routing.
  1. Seat post & Seat rail postion
    By spacoli in forum Beginner's Corner
    Last Post: 09-23-2004, 02:26 PM
  2. Blur seat post shim (30.9mm OD) Anyone make one?
    By CraigH in forum Santa Cruz
    Last Post: 04-15-2004, 09:11 AM
  3. Seat post & Seat rail postion
    By spacoli in forum General Discussion
    Last Post: 01-24-2004, 04:13 PM
  4. Pazzaz seatpost vs. Stock Spec Enduro post weight?
    By phil. in forum Weight Weenies
    Last Post: 01-21-2004, 06:49 PM
  5. Seat post clamp size for a 31.6 post?
    By AMcK in forum Weight Weenies
    Last Post: 01-19-2004, 09:27 AM
